Guest Posted March 26, 2009 Posted March 26, 2009 If i was to jet up my carb would it make a huge amount of diffrence on a 50cc? Quote
Guest Posted March 26, 2009 Posted March 26, 2009 If i was to jet up my carb would it make a huge amount of diffrence on a 50cc?no. Quote
Ingah Posted March 27, 2009 Posted March 27, 2009 Interestingly enough as part of restricting a CB500 you replace the standard #122 jets with #125 jets (i believe this is upjetting, no?) Quote
Guest Posted March 27, 2009 Posted March 27, 2009 jetting would change the amount of fuel on a 50cc there will only be 50cc of air /fuel mix (correct me if i'm wrong?) so all you would get is a richer mixture.. which is nice if you've uprated things so the engine needs it as in it is running lean due to a better air filter (more air/inhale) and non standard exhaust (faster exhale)save your money, buy a 125 and do your test.. Quote
