Guest Posted April 7, 2009 Posted April 7, 2009 Hey guys, I'm not usually too bothered about a little oil - but I'm driving (riding) down to wales to my mums place tomorrow If it was serious my bike wouldn't be going would it? Its running FINE but has a little oil leak on the head gasket Quote
tony-1977 Posted April 7, 2009 Posted April 7, 2009 Personally I would change the head gasket. If it's seeping though outside, will it be leeking inside too? Quote
rosszx9r Posted April 7, 2009 Posted April 7, 2009 Hey guys, I'm not usually too bothered about a little oil - but I'm driving (riding) down to wales to my mums place tomorrow If it was serious my bike wouldn't be going would it? Its running FINE but has a little oil leak on the head gasket i wouldn't get too worried about it. if it's an oily stain then clean it off for now and see if it gets worse.you should have around 5 litres of oil in your engine so unless you're loosing it by the cupful every day, it'll be fine until you have time to take a closer look you'll need to look close to see if it's the head gasket or the rocker cover gasket. it's most likely the later and in this case is easily fixed and cheap to do (~£5 for new gasket)if you can send a photo of the leak, it would help... Quote
Guest Posted April 9, 2009 Posted April 9, 2009 I have cleaned it off and its not showing up so must be a slow leak Quote
chrisgatguis Posted April 10, 2009 Posted April 10, 2009 Is it common to leak from the rocker cover Ross? Mine spits from there, doesn't amount to much but is a bit messy on the down pipes.is it just a case of taking the cover off and replacing the gasket? like you don't have to empty all the oil out do you? Quote
Bill_on_a_bike Posted April 10, 2009 Posted April 10, 2009 Oil shouldn't spit from your rocker covers no, oil should never leak.Yeah you can take the rocker covers off without emptying it of oil, let the engine sit for a bit first if it's been running.Gasket on mine are a rubber seal set in to the rim of the rocker cover, but it's not round it's ovular. Dno how hard these are to source. Quote
rosszx9r Posted April 11, 2009 Posted April 11, 2009 Is it common to leak from the rocker cover Ross? Mine spits from there, doesn't amount to much but is a bit messy on the down pipes.is it just a case of taking the cover off and replacing the gasket? like you don't have to empty all the oil out do you? it's comon because you need to take it off for certain service checks like valve clearances so because it gets distrurbed, there is a chance it will leak. it shouldn't and it will only leak if it's been damaged or fitted incorrectly. it's a really easy thing to fix. usually 6 or 8 bolts hold the cover on. no need to do anything special and certainly don't need to drain the engine oil. Quote
Guest Posted April 11, 2009 Posted April 11, 2009 it shouldn't and it will only leak if it's been damaged or fitted incorrectly. it's a really easy thing to fix. usually 6 or 8 bolts hold the cover on. no need to do anything special and certainly don't need to drain the engine oil.or the gasket has been damaged and not changed.. so get a new gasket then drop the top as per RossZX9R and reift, remembering not to undo or tighten bolts clockwise/anticlockwise but in a alternate pattern.i.e bolts read R-L top 1 - 2 - 3 - 4, Bottom, 5 - 6 - 7 - 8.undo 1, 8, 4, 5, 2, 7, 3, 6. see haynes manual for more info this stops the head warping and trapping the gasket. tighten all hand tight then use socket. Quote
chrisgatguis Posted April 11, 2009 Posted April 11, 2009 cheers, I'll have a look through the haynes and get the gasket ordered! Quote
