Not so much a big motorbike as all you pro's are riding, but i have Peugeot Trekker 100 scooter.
The problem is, i had to get a new exhaust fitted, me and my dad done it ourselves but we went wrong and didnt oil the piston and/or barrel so had to get a new one. When we put the exhaust on ourselves, were it connects to the engine, there was 2 pins for the pipe to fix to.
Now that ive got it back, i noticed it was proper loud considering its got a new exhaust, so i had a look around an noticed tha the bottom pin were the exhaust connects isnt there. Are they replaceable and will it be alot of work just for that small thing?
I cant be doing with riding round on the bike while its making the noise of a thousand bee's!
Cheers
Is it a screw in lug, or welded in place and did it fall or get snapped off?
Either way it shouldn't be that big a job, although I'm not familiar with the type of bike.
OK, But I'm at work and can't see pics there! :bang:
I'm not at home until Friday either, but someone else will help you out long before then! :cheers:
Its fixed down with a nut! Ill take a picture, its hard to explain
send a picture, by the sounds of it you have a broken stud, and would need to remove the front of the exhaust, get a new stud and a stud extractor or if possible mole grips and remove and replace, putting the front pipe back on with the nuts.. picture will help me claify this
It would appear ive sorted it myself!
Here are the first pictures i took tryin to find the problem...
http://i209.photobucket.com/albums/bb217/rfn_rigby/DSC00692.jpg
http://i209.photobucket.com/albums/bb217/rfn_rigby/DSC00694.jpg
http://i209.photobucket.com/albums/bb217/rfn_rigby/DSC00696.jpg
But heres the problem...
http://i209.photobucket.com/albums/bb217/rfn_rigby/DSC00699.jpg
And a missing bolt from the other lug hole! Im going to go back the garage and complain, and ask for a new gasket! I have a bolt that fits
i would take the bike back to the garage and get them to fix it for free, after all you've paid once, otherwise a refund of costs and the gasket otherwise you've paid good money for nowt.
it helps if the shops busy when you do this, no one likes bad publicity.....
I like tha idea! Cheers for the advice! Will pay them a visit tomorra with whats left of the gasket in hand!
