JoshTimmins Posted April 14, 2009 Share Posted April 14, 2009 Went out on the bike for the last 2 nights.. gettin it outa me garden i need to do a sharp right turn.. soo full lock... now this starts to kill the engine.. starts to die. keep a few revs on while like this, or turn back it stops dieing. Any ideas?!Is there a cable loose, and turnin it right is affecting this? Thanks for your helpJoshxand yes i am surprised too ! 2nights on the bike! who wuld believe it! Quote Link to comment Share on other sites More sharing options...
Guest philgale Posted April 14, 2009 Share Posted April 14, 2009 could be coz its just cold and needs warming upor its either stretching or slacking a cable off just have a look when its stood still if its restricting anything when on full lockdoes it do anything when you turn while riding it? i.e u turns Quote Link to comment Share on other sites More sharing options...
Guest Posted April 14, 2009 Share Posted April 14, 2009 Put the bike on the centre stand and move the bars left lock to right lock and see if occurs under those conditions - sounds like a snagged or faulty throttle cable to me though. Quote Link to comment Share on other sites More sharing options...
JoshTimmins Posted April 14, 2009 Author Share Posted April 14, 2009 ok quickly checked. found the problem, i think.full lock right, strectches the choke cable turnin the choke on - dead.This is after we had to amend the position of the choke cable when we changed speedos. Soo my answer is thisdo i have to have this bit on the bike, and for the choke to work, wanna double check before i take it off, i dont use it anyway.http://shop.wemoto.com/pictures/full/CABLE_CHOKE_HONDA/10004506.jpgThanksJoshx Quote Link to comment Share on other sites More sharing options...
chrisgatguis Posted April 14, 2009 Share Posted April 14, 2009 Hi mate, I'd aim to keep it if you can, when the bikes cold and IN the cold it might not start v well and hence need the choke..I'd try taking it off at the engine end and re route it.Shouldn't be too hard to do just a bit of trial and error (unless you know the correct route) Quote Link to comment Share on other sites More sharing options...
JoshTimmins Posted April 14, 2009 Author Share Posted April 14, 2009 Hi mate, I'd aim to keep it if you can, when the bikes cold and IN the cold it might not start v well and hence need the choke..I'd try taking it off at the engine end and re route it.Shouldn't be too hard to do just a bit of trial and error (unless you know the correct route) i have to use the choke by the side of the engine rather than this anyway cos i need a new one.. think ill order a new one and then re-route it cheers allJoshx Quote Link to comment Share on other sites More sharing options...
Guest Posted April 14, 2009 Share Posted April 14, 2009 Hi mate, I'd aim to keep it if you can, when the bikes cold and IN the cold it might not start v well and hence need the choke..I'd try taking it off at the engine end and re route it.Shouldn't be too hard to do just a bit of trial and error (unless you know the correct route) i have to use the choke by the side of the engine rather than this anyway cos i need a new one.. think ill order a new one and then re-route it cheers allJoshxget your dad to knock up a bracket, so its not fowling anything lock to lock (full left to full right (Lockstops)). Quote Link to comment Share on other sites More sharing options...
