META 351A won't disarm!!!
HELP!!!
I have a Gixer 750 with a Meta 351A fitted.
I am having a major headache with it!!! When you try to start the bike the alarm triggers and
the immobilser comes on. The alarm wont switch off and i have tried to reset it using the code on the little red card that came with the bike using instructions from the Meta website but it still won't work!!!!
Any ideas???
Sue
I've changed the batteries in both fobs, checked all fuses, made sure bike battery was charged but no joy! When disarming with code the alarm did stop for about 5 mins but the immobiliser stayed on
Sue
Might sound odd, but I saw an article somewhere that said mobile phone masts can interfere. Assuming your alarm has been fine in this same location... it might not be the case. If the bike is in a new (to the bike) location or some snide buggers have put up a phone mast...... try wheeling it a couple of hundred yards down the road. Bit of a bugger if it doesn't work cos you gotta push it back again...... But just sharing what I've heard.
Sorry to say I had this problem with my meta alarm 2 years ago and it was the alarm itself that was gone, I ended up getting it removed.
