Ant132 Posted April 15, 2009 Posted April 15, 2009 hi, my bike was fine and ran great but i took it out monday and i couldnt get past 5,000 rpm, as soon as it got to 5,000 it kinda went pop,pop,pop,pop, until i knocked it up a gear and it would go again, until the same would happen again once the revs hit 4/5k.Ive been working the last few days to fix it to no avail, ive cleaned the carbs, checked the connections to the cdi, generator, ignition coil and cdi pick up. and generally checked the connections of the whole loom, and also checked for any air leaks. The bike revs up fine in neutral, but wont go past 5,000 under load.I have now found out that i can get to 6,000 in 1st, 5,000rpm in 2nd and 4/5,000 in 3rd, 4,000 in 4th etc. etc. Any ideas. thankfull to any help from experience!!!Bike is honda cb400n superdream, air-cooled 4-stroke twin cylinder. I also replaced the rocker cover gasket in the same day, then took it out to find this problem.thank you Quote
Guest Posted April 16, 2009 Posted April 16, 2009 Bike is honda cb400n superdream, air-cooled 4-stroke twin cylinder. I also replaced the rocker cover gasket in the same day, then took it out to find this problem.thank youhow was it before your repairs? Quote
Ant132 Posted April 16, 2009 Author Posted April 16, 2009 Bike is honda cb400n superdream, air-cooled 4-stroke twin cylinder. I also replaced the rocker cover gasket in the same day, then took it out to find this problem.thank youhow was it before your repairs? Absolutely fine, the one and only thing i did replace the rocker cover gasket.Thanks Quote
Guest Posted April 16, 2009 Posted April 16, 2009 Bike is honda cb400n superdream, air-cooled 4-stroke twin cylinder. I also replaced the rocker cover gasket in the same day, then took it out to find this problem.thank youhow was it before your repairs? Absolutely fine, the one and only thing i did replace the rocker cover gasket.Thanks It has to be something from your repair, did you refit the breather and pipes correctly? Quote
Ant132 Posted April 16, 2009 Author Posted April 16, 2009 Everything fitted correctly mate!! To tell the truth since posting this yesterday ive now found out some more information on similar problems etc. and im led towards generator failure. There is apparently two parts on the superdream generator, one that controls starting and upto 4/5k and another that controls rpm over that. So it is likely that the generator has failed due to them being a weak point in the superdreams electrical system. If it is the gen, then chances are it is just some mad kind of coincidence as honestly, every last thing i could have checked to do with the simple gasket fit has been checked and re-checked by me and my dad who was helping me yesterday. What you reckon to this mate? Is it worth me splashing out on the gen or am i barking up the wrong tree? Quote
Voodoo Posted April 16, 2009 Posted April 16, 2009 I just guessing but if it doesn't rev past 5000 only under load, then I would have thought it would be a fuel or air problem, not an electrical problem.Don't take my word as gospel though, I ain't no expert Quote
Guest Posted April 16, 2009 Posted April 16, 2009 Everything fitted correctly mate!! To tell the truth since posting this yesterday ive now found out some more information on similar problems etc. and im led towards generator failure. There is apparently two parts on the superdream generator, one that controls starting and upto 4/5k and another that controls rpm over that. So it is likely that the generator has failed due to them being a weak point in the superdreams electrical system. If it is the gen, then chances are it is just some mad kind of coincidence as honestly, every last thing i could have checked to do with the simple gasket fit has been checked and re-checked by me and my dad who was helping me yesterday. What you reckon to this mate? Is it worth me splashing out on the gen or am i barking up the wrong tree?i would search the site for Regulator or rectifier, i posted a link from the Katana Club site regarding checking them, and you'd need a multimeter to measure amps/voltshttp://www.thegsresources.com/garage/gs_statorfault.htm Quote
rosszx9r Posted April 17, 2009 Posted April 17, 2009 hi, my bike was fine and ran great but i took it out monday and i couldnt get past 5,000 rpm, as soon as it got to 5,000 it kinda went pop,pop,pop,pop, until i knocked it up a gear and it would go again, until the same would happen again once the revs hit 4/5k. just dug out my old haynes manual for the 400n, it states that engine fade under load is due to preignition and typically faulty plugs. it's listed as an explicit example in the fault finding section i also looked at the alternator part. the cdi pickup is integrated with the alternator but it makes no reference to there being two parts opperating at different RPM (it would be odd if there were). what you do have is the cdi pickup in the alternator operating the ignition advance device.i would suggest you check/replace plugs, check the state of your HT with a spark gap tester (checking for a spark on the end of a plug isn't enough). then double check the cdi pickup connector on the alternator (make sure the spade connectors aren't corroded or pushed back inside the connector housing and that the pickup is mounted securely)(remember, you would of disconnected the HT when taking the rocker cover off. it's possible you bent an HT lead and the insulation cracked or the connection came loose at the coil or plug cap ends. the HT lead just screws into the connector!)if all that is ok, should check/replace the cdi pickup. haynes doesn't even list a test method. just says change if thought to be faulty. if you have access to a timing strobe, you can check it quite easily i'd of thought.hope that helps... Quote
chrisgatguis Posted April 17, 2009 Posted April 17, 2009 Hi Ant,up to 5k revs is everything okay? i.e. normal power etc? Quote
Ant132 Posted April 17, 2009 Author Posted April 17, 2009 Thanks Ross, some good advice there. Will keep me busy this afternoon! Hi Ant,up to 5k revs is everything okay? i.e. normal power etc? Yes mate, the same as before. Still starts great and idles fine, the power under 5k is the same. No power loss or anything. Quote
