Powder Coating
Guest Ninja-Bear
Guest Ninja-Bear
Hi has anyone had expereince of having their wheels powder coated ? I want mine doing black but not sure best option for doing it. Is gloss or matt easiest to keep clean ? Any other info appreciated cheers :wink:
personally i would go for gloss i like a shiny finish myself,either way let us know how you get on :wink:
Gloss is far easier to keep clead,'specially when removing 'chain-fling'.
J.
i must admin, a matte finish looks good.. (subframes etc.) but wheels deffo gloss, u just want something u are able to give a quick wipe to clean..
My wheels came stock matt black,and I had them powder coated after 12 months,believe me when I say gloss is far easier to keep up to,and personally I think it looks better,or at least 'smoked chrome' does :D
J.
Guest Ninja-Bear
4 - 0 gloss think that does it for me :D Are there any variations on how powder coating is done or is it the same process anywhere you go :?:
its basically the same process HOWEVER the main difference between the company's that do the service is preparation. If your wheels are poorly stripped of any coatings or residual oil is left the finish can suffer. I would go to a personally recommended outfit and preferably one that does mainly automotive parts. Agricultural, office or garden equipment are often blasted with large coarse beads (or even grit) this method of cleaning/striping often reduces the fine finish required for your bike. One other thing, consider replacing your wheel bearings at the same time as you should remove them prior to the coating.
I personally recommend Tripple S in Bingley. They are a little pricey but the finish is worth the extra few quid.
Nigel Fenton
Guest Ninja-Bear
Yeh I know a guy who does my car wheels and hes a top bloke, was gonna see him. And I was goning to replace the wheel bearings as a matter of course, cheers for the advice :wink:
The place i used for my wheels m8 charge £40 a wheel :D Did a nice job aswell :D Ohh and i went for Gloss................BLACK :lol:
Metal-Magic in Barnsley coated my wheels.
Cost £72.00 for 2 wheels 'soft bead' blasting and coating of 'smoked chrome',which incidently is a dearer finish than a plain gloss.
Been done for 6000 miles,and a tyre change,still no visible marks or chips.
J.
  • 2 weeks later...
sorted this out by now..
But there's also a company called "Peateys" in Yeadon/Horsforth area of Leeds - supposed to be quite good...
LSN in Castleford... theu usually go to ruffoth sat si i'll get u some prices
mine are gloss with protective coating of "road muck" widely available from good roads
Frame swing arm and wheels done in Matte Black . price was 35 per wheel 15 swing arm 55 frame. Cracking price cracking job too.
RandR powdercoatings in West Tanfield (Near Ripon).
01677470808
  • 4 weeks later...
