cr250 gearbox
just bought a cr250 1997 and the the gear peg keeps coming loose and a cant change gear when i take the gear peg off the gear selector rod is a bot rounded on the front teeth but some of the back teeth are ok also the gear peg teeth are rounded
so a bought a new gear peg and that cant get a good grip of the selector rod
CAN I GET THE TEETH FIXED OR WILL I HAVE TO GET A NEW GEAR BOX ALSO ANY IDEA HOW MUCH THIS WILL COST?
I had a bike that had the same problem. To fix it I drilled a small hole smack bang in the middle of where the teeth should grip each other and inserted a small dowel (i.e a nail). Then when I tightened the nut it was ok
  • 2 weeks later...
Guest David
I did the same sort of things years ago, I drilled a whole straight through the lever and the shaft and put a small nut and bolt through it.
