Rigger Posted April 27, 2009 Posted April 27, 2009 Had a sports exhaust fitted an ive been advised to look after it, keeping it free from rain were possible because its raw metal. Wha can i use to keep it rust free and/or remove any rust already there?Its gonna be a pain, but im not forking out more money for yet another exhaust.Cheers Quote
Guest Posted April 27, 2009 Posted April 27, 2009 when you say raw metal what type of raw metal mate ? Quote
Rigger Posted April 27, 2009 Author Posted April 27, 2009 Err... im not sure haha! How do i found out? Quote
Rigger Posted April 27, 2009 Author Posted April 27, 2009 http://i209.photobucket.com/albums/bb217/rfn_rigby/DSC00719.jpgThats the exhaust, if itll be any help! Needs a clean! Quote
Stu Posted April 27, 2009 Posted April 27, 2009 i would have painted it with exhaust paint before fitting Quote
cruz Posted April 27, 2009 Posted April 27, 2009 i would have painted it with exhaust paint before fittingAnd then an exhaust wrap perhaps ? Quote
Rigger Posted April 27, 2009 Author Posted April 27, 2009 Does the paint protect it, and whats an exhaust wrap/picture/were i can purchase one? Quote
cruz Posted April 27, 2009 Posted April 27, 2009 Used in motorsport too.http://www.exhaustwrapshop.com/default.aspx Quote
Rigger Posted April 27, 2009 Author Posted April 27, 2009 £50 for some tape? Ill pass! I suppose it will be worth it though... Quote
Pete Posted April 27, 2009 Posted April 27, 2009 If you do decide to take it off and want to keep the metal look you could always try one of those steel wire brush drill bits to get all the crap off it and polish it up nicely. It'd take time to do but once you've got it shiny you could then either paint it or treat it with some clear metal lacquer (but get a heat resistant one!) to stop rust coming back. Quote
Guest Posted April 27, 2009 Posted April 27, 2009 I think its aluminium rather than steel so a wire brush will scratch the crap out of it Quote
Rigger Posted April 27, 2009 Author Posted April 27, 2009 Id say its too heavy to be alluminium! What would you reccomend though? Quote
rosszx9r Posted April 27, 2009 Posted April 27, 2009 I think its aluminium rather than steel so a wire brush will scratch the crap out of it it's not ally..... it would melt i bought a polishing kit from MandP to polish my wheels. it works great and only cost £17 for all the brushes and compounds.and as already said, laquer it after although, good luck finding a heat resistant laquer!might be easier just to paint it silver??? Quote
Rigger Posted April 27, 2009 Author Posted April 27, 2009 I dont mind giving it a bit of work like, gives me more of a 'thats my bike' sort of feeling. Ive just bought 3 tins of this stuff!Cylinder Black Car Motorcycle & Stationary Engine High Temperature PaintThis heat resistant paint has a satin finish and is ideal for exhaust systems on classic vehicles and kit cars. Can be used on exhaust manifolds, motorcycle engine barrels engine blocks and casings, cylinder heads etc.Does not require a primer, just apply to clean degreased surface. Can be brushed or sprayed when thinned with cellulose thinners.Will resist flaking and cracking and will protect metal surfaces from corrosion to keep your classic in good condition. Contains 250ml£6.99 a pop, any opinions/tips for me? Quote
Guest Posted April 27, 2009 Posted April 27, 2009 I think its aluminium rather than steel so a wire brush will scratch the crap out of it it's not ally..... it would melt i bought a polishing kit from MandP to polish my wheels. it works great and only cost £17 for all the brushes and compounds.and as already said, laquer it after although, good luck finding a heat resistant laquer!might be easier just to paint it silver???get engine paint in a rattle can from halfords, avail in aluminum or black , and red it thats your thing Quote
Guest Posted April 28, 2009 Posted April 28, 2009 The RS 11 RS-II essence dressed up in chromium still sctratch the crap out of it mate Quote
Pete Posted April 28, 2009 Posted April 28, 2009 Just thought - if you do use a wire brush polishing kit it might be a good idea to try and get hold of brass ones. If you use steel ones then fragments could embed themselves into the exhaust and introduce rust. I guess if you're going to treat it though it won't make any difference, but just thought I'd mention it! Quote
Rigger Posted April 28, 2009 Author Posted April 28, 2009 Cheers for the tips fellas! Appreciated Quote
