Guest Posted May 13, 2009 Posted May 13, 2009 I was thinking, how does a 600cc cylinder produce so much more power than that of a 125cc cylinder? I mean, there would be more fuel and air, but i cant understand how it would create that much more power? Please explain Quote
dredge3 Posted May 13, 2009 Posted May 13, 2009 I was thinking, how does a 600cc cylinder produce so much more power than that of a 125cc cylinder? I mean, there would be more fuel and air, but i cant understand how it would create that much more power? Please explain You said the answer..more fuel and air...bigger bang = more power Quote
Guest Posted May 13, 2009 Posted May 13, 2009 Yeah, but there cant be that much more fuel and air to boost the power up that much, can there ? Quote
Guest akey Posted May 13, 2009 Posted May 13, 2009 Fuel / air ratio stays constant so for if we compare 100 to 600cc then the 600cc bike will be 6x as powerful. now its not that simple because of the other mechanics involved but on a simple level more air and fuel means more power.This is also how superchargers and turbos work as they cram more air and fuel into the same space. Quote
Bill_on_a_bike Posted May 13, 2009 Posted May 13, 2009 BUT, in a great big 600cc single, the air and fuel haven't got enough time to spread out properly, so the combustion tends to be less completel. You can over come this a few ways. 2 inlet valves helps to get the fuel air in to more of the cylider in one go. Audi used to have a valve system that sent the gas in spinning so it would spread out more evenly and burn more evenly.Also, a great big piston like that can't rev as fast as a smaller one, just because moving that much metal that fast is technically much harder to do than moving a small piece of metal that fast. I know yamaha had problems with prototype SR 500 engines with the piston cracking at higher RPMs.All sorts of far out stuff to consider with these things. I can't wait 'til i know more about them all. Quote
jamesw Posted May 14, 2009 Posted May 14, 2009 It's also worth considering that power is a function of force and time. So in simple terms an engine which is able to rev higher (and most 600s will rev higher than most 125s) is able to produce more power given that all other things are equal. So with an increased capacity and an ability to rev higher, a 600cc engine will make substantially more power than a 125cc engine. Quote
dredge3 Posted May 15, 2009 Posted May 15, 2009 This thread could get messy Don't forget compression ratio Quote
chrisgatguis Posted May 15, 2009 Posted May 15, 2009 Id say the bottom line is basically what every one has said.Its 5 X bigger therefore generates "5 x more power" or equivalent.think of a 1 litre car, versus a 5 litre car..seemples Quote
Guest Posted May 16, 2009 Posted May 16, 2009 Id say the bottom line is basically what every one has said.Its 5 X bigger therefore generates "5 x more power" or equivalent.think of a 1 litre car, versus a 5 litre car..seemples But it would also use 5 times more fuel, i guess they just have big tanks! Quote
chrisgatguis Posted May 16, 2009 Posted May 16, 2009 In theory maybe,but in reality its a lot harder (more revs) for a 125 to cruise at 60mph,compared with a 600 cruising at the same speed your probably talking half the Revs (or less)so it pans out in the end.saying that a 125 will probably do twice if not three times more MPG than a lot of other larger bikes.my CBR125 would get 98 mpg consistantly, my GS500 managed 80 once and 60 once, so it varies on how you ride it.Not sure what my 600 can do Quote
jamesw Posted May 16, 2009 Posted May 16, 2009 but in reality its a lot harder (more revs) for a 125 to cruise at 60mph,compared with a 600 cruising at the same speed your probably talking half the Revs (or less) but then that depends on the gear ratios! This thread could get messy Quote
chrisgatguis Posted May 16, 2009 Posted May 16, 2009 but in reality its a lot harder (more revs) for a 125 to cruise at 60mph,compared with a 600 cruising at the same speed your probably talking half the Revs (or less) but then that depends on the gear ratios! This thread could get messy Fine fine, well if we're getting petty the real reason is this:on your 125 your are approx 0.5 inches lower down (hence closer to the earths core) than on the no doubt bigger 600.Due to this you get a increased gravitational pull on the pistons in your engine, (horizontal mounted may be different ) therefore you only get 14 bhp if you are lucky.It is in deed nothing to do with the size of the engine........ Quote
jamesw Posted May 16, 2009 Posted May 16, 2009 But that would make the induction and power strokes more efficeint (assuming the engine is mounted with the piston crown facing vertically upwards ) Quote
Bogof Posted May 16, 2009 Posted May 16, 2009 Being further away from the sun would mean that the engine would run colder though Quote
dredge3 Posted May 16, 2009 Posted May 16, 2009 Also colder intake temparature increases power.......here we go. Not looking at this thread anymore. More cc = more power, unless... Quote
Guest akey Posted May 16, 2009 Posted May 16, 2009 Colder intake = more power, only if your fuel system takes account of the air density (cold air being denser than warm air hence has the potential to produce more power, if more fuel is put in).he he sorry Quote
Pete Posted May 16, 2009 Posted May 16, 2009 What a truly thrilling installment this is! I'm on tenterhooks waiting for the next exciting, yet informative episode... Quote
Guest Posted May 17, 2009 Posted May 17, 2009 Well, at least i learnt something through all this mess.. bigger CC = more power no questions asked Quote
Bill_on_a_bike Posted May 18, 2009 Posted May 18, 2009 Hmm, 'fraid notthe brough superior 11.50 I rode had 8 horse power, about 2 thirds what a 125 knocks out. Quote
jamesw Posted May 18, 2009 Posted May 18, 2009 Also colder intake temperature increases power....... ...don't forget the effects of atmospheric pressure (and therefore altitude) and quite possibly (but on a much smaller scale) air and fuel composition Quote
Colin the Bear Posted May 18, 2009 Posted May 18, 2009 Isn't the simple answer that the 125 is restricted in its power output to conform to legal requirements. Quote
Bill_on_a_bike Posted May 19, 2009 Posted May 19, 2009 Also colder intake temperature increases power....... ...don't forget the effects of atmospheric pressure (and therefore altitude) and quite possibly (but on a much smaller scale) air and fuel composition This is exactly why aeroplane engines have to be supercharged or turbo charged, to get enough oxygen in to burn a useful amount of fuel.the term "inter-coolers" comes from aero' engines having several superchargers, with coolers inbetween them to make the air denser. The prefix inter is now obselete as there's rarely more than one supercharger per intake manifold. We should call them "after-coolers".Spot the engine geek. Quote
