iv noticed that iv got a leak coming from the steel radiator hose on the bike dose this have a other name as iv put in steel radiator hose for z750s in google and its come up with every part the is except for the one im looking for?
What does your manul call it? Or don't you have a manual for the bike?
are you sure its a steel hose, sounds unlikely.. does it have a rubber fitting or o-ring that may be unseated..
yeah its steel it as a rubber hose from the radiator to the steel hose and that go under and to the back of the engine
you can just make it out in pic
http://img.thesun.co.uk/multimedia/arch ... 66028a.jpg
Is it here...
http://i250.photobucket.com/albums/gg250/simonevans73/Mynd_17.jpg
where the pipe joins the water pump, the pipes comes under the engine from the front.. so could be the seal at the water pump..
