Guest Posted May 25, 2009 Posted May 25, 2009 My XJ600N has developed revs problems, could this be anything to do with the TPS, if so what are the signs of malfunction or mis-adjustment? thanks Quote
Guest Posted May 25, 2009 Posted May 25, 2009 My XJ600N has developed revs problems, could this be anything to do with the TPS, if so what are the signs of malfunction or mis-adjustment? thanksfix your vacuum pipe then come back, it may be your posting several threads about the same problem... Quote
Guest Posted May 25, 2009 Posted May 25, 2009 To check the TPS on my fazer I needed to disconnect and reconnect it and turn the ignition on... if the needle was at 5k all is well, if at 0 or 10k it needs adjusting... ...dunno if its the same with yours, but as WalneyFrankie says, get your other issues sorted first Quote
