Anyone offer advice on a pair of paddock stands? I want a pair for the fireblade but I have no idea where to begin shopping. Ideally I'd like a set that I could use on other bikes too - are "universal" ones really universal? Good brands and sources?
Thanks in advance! :D
get an ABBA STAND as you will be able to do the front forks.
there around £80-£100 with the fitting kit.
i have the standard front and rear stands and your a bit limited service wise :x
Guest philgale
get a head stock stand if you dont want an abba, the front stands i have aint the best. next on my list is one of these
http://handy-lift.com/global/images/part_class_images/thumbs/tfront-headstock-stand2093-.jpg
you can get a rear stand like this
http://www.motorbike-search-engine-shop.co.uk/Shop/ToolsPics/FS/new%20rear%20paddock%20stand.jpg
just uses the swing arm to lift the back.
Guest philgale
Better off getting some bobbins and a stand to suit for the back much safer and easier to use.
agreed, but for just taking it off and using it on another bike....spose you could get bobbins for both bikes
Guest akey
Abba stand all the way mate, its the best bit of kit ever.
Thanks for the suggestions all. I ended up ordering an Abba superbike stand kit. I should be able to use the front lifter on the tiger as well! :D
same here execept green
My Bike!!!!!!!!!
*link removed*
Post anymore and your account will be removed too. I have better things to do than chase you round the forum. Thanks. admin.
Is stalky a spammer?
Sorry if you're not. Just noticed a pattern in your posts.
