Hi there,
I have just been doing some checks on my bike, and noticed that the coolant level appears to be on the low side. I'm relatively new to riding and was wondering what coolant brands to go for? Is coolant the same as the antifreeze you put in a car??
Any advice appreciated!
Yes, coolant is the antifreeze and water mix, for quanties, see the back of the bottle..
if you're just topping it, there shouldn't be much to it..
thanks for that. would you recommend any particular brand?
There all very much the same, just get the ratio right,.. i.e. 3 parts water to 1 antifreeze.. this is an example, ratio should be on the back of the bottle.
looking on halfords, you can be ultralazy and get readymixed....
