Phil_D Posted June 14, 2009 Posted June 14, 2009 I seem to be missing a bolt on my honda cbr600f4, its one of the ones that bolts the windscreen onto the fairing (i think theres about 6 of them in total). Where would i be able to pick one of these up from? Quote
Pete Posted June 14, 2009 Posted June 14, 2009 I've got two or three fairing screws missing on my screen! They're on the inside though and it's secure so I'm not bothered. You can get new ones from Halfords of all places. Click here to see the ones I mean.If you go in-store to get them they're on the end of the isle on a hanger. Well they are in my local one anyway. Quote
Guest Posted June 14, 2009 Posted June 14, 2009 screen bolts are available in the masses, colours etc, try halfords as per SP, or your local bike shop, Quote
Phil_D Posted June 14, 2009 Author Posted June 14, 2009 I looked at the screen screws on the halfords website and they all seem to require a nut on the other side, i unscrewed the bolt on the otherside of th windscreen and it doesnt have a bolt, it just screw into the fairing, its only the upper bolt on each side that have nuts on the other side, they are also different in diameter. Quote
Guest Posted June 14, 2009 Posted June 14, 2009 I looked at the screen screws on the halfords website and they all seem to require a nut on the other side, i unscrewed the bolt on the otherside of th windscreen and it doesnt have a bolt, it just screw into the fairing, its only the upper bolt on each side that have nuts on the other side, they are also different in diameter.any chance of a pic? Quote
Pete Posted June 14, 2009 Posted June 14, 2009 Fairing screws go into fairing clips like these. They clip onto the fairing and you screw into them. They're used instead of nuts, so if you did buy the ones from Halfords you could just not use the black nuts that come in the pack.Or do what Frankie says and just try a local bike shop Quote
Guest Posted June 14, 2009 Posted June 14, 2009 Fairing screws go into fairing clips like these. They clip onto the fairing and you screw into them. They're used instead of nuts, so if you did buy the ones from Halfords you could just not use the black nuts that come in the pack.Or do what Frankie says and just try a local bike shop What suzukipetes posted is a dzus fastener, these turn 90 degrees.. and are used as fairing clips for quick release, i doubt this is what you have on your screen. the screen mounts to the fairing with chimney nuts (black rubber nuts that compress) and i would suggest two bolts that holds the thing to the fairing frame/brace. have a look on tastynuts site.. http://www.tastynuts.com/site/frames/fr ... online.htm Quote
Colin the Bear Posted June 14, 2009 Posted June 14, 2009 http://www.mr-fastner.com/products.asp?cat=23 Quote
Phil_D Posted June 15, 2009 Author Posted June 15, 2009 Heres a pic of the bolt i mean (not my bike)http://i111.photobucket.com/albums/n135/loopingdragon/cbr2.jpghttp://i111.photobucket.com/albums/n135/loopingdragon/cbr1.jpgIt doesnt have a nut the other side which the screen bolt above it does, it is also a lot smaller in diameter than the bolt above which makes me think i cant just buy a universal bolt Quote
Guest Posted June 15, 2009 Posted June 15, 2009 Heres a pic of the bolt i mean (not my bike)http://i111.photobucket.com/albums/n135/loopingdragon/cbr2.jpghttp://i111.photobucket.com/albums/n135/loopingdragon/cbr1.jpgIt doesnt have a nut the other side which the screen bolt above it does, it is also a lot smaller in diameter than the bolt above which makes me think i cant just buy a universal boltsorry meant a pic of the other bolt, i take it you have the opposite side..what does it screw into.....? Quote
Phil_D Posted June 15, 2009 Author Posted June 15, 2009 sorry meant a pic of the other bolt, i take it you have the opposite side..what does it screw into.....?Seems to screw straight into the front fairing, il get a pic of it in a day or so when i can get hold of a camera Quote
