Motobike... Waw!
Hey people, I'm back aint been on here for a while...
I sorted the Exup Valve and all the other stuff... I think ha...
One more thing left to do I think anyway.....
I have a fuse problem, there was a '20' in there, for the Rev, Indicators, and Lights... But it blew, bought another one, blew, bought 3 of them, and put a 25 in there, blew, 30 in there blew, but... put another 25 in there to see how it is doing it, went home, all ok... stopped at a junction turned my lights on, indicators, and breaks were on, so pretty much all the things were on, carried on going home, and just as a I put my clutch in, went through the gates and it just went, bike still goes but all the lights turned off and rev clock stopped, I really can't figure out what it is...My bro things it might be the regulator... Anyone got any wisdom to share?
Sorry can't help with the problem, but I wouldn't go fitting higher rated fuses because one is blowing. You could end up burning out something expensive, fuses are rated for a reason you know. 8-)
if it was the regulator, i doubt you'd have had them on without it blowing, check your wiring for a bad earth / frayed-damaged wiring.., its tripping out on the frame..
You could have water in one of your connections under your dash, I had the same thing a few years ago, fuse just kept blowing, so I disconnected everything and there was dampness in the headlight connector, dried it out and it was fine. Took bleeding ages to put the bike back together again. Strangely I always seem to have screws and bolts over everytime, oh well I suppose it cuts down on the weight :roll:
Moved into Pitstop for ya :thumb:
I was gonna say ... 'Walney Frankie will find it in there.. ' but he already has ... :mrgreen:
Haha, cheers people... I think I'm going to go with the Water in the connections somewhere... We had a really heavy rain day yesterday... and my t-shirt under the seat was wet... So I think there could actually be water in the fuse bit itself. Or in the indicator one.
If fuses are blowing its for a good reason, don't just keep replacing them or you will cause more problems.
I would go with what others have said, its probably down to a short somewhere either from damp getting in, or from worn / frayed insulation.
I would start by checking all your connection points and putting some white lithium grease in them to repel the water, do a physical check of all your wires where they come close to other bits, and where they are clamped.
Hope you find it ok mate.
