Guest Posted June 16, 2009 Posted June 16, 2009 hi,when my ignition is on, the lights are on, and the light switch wont turn on/off, it will go brighter and dull, but you can turn the ignition of and the lights are of, it's just the lights wont go off at all, when ignition is of. Quote
stevie16v Posted June 16, 2009 Posted June 16, 2009 Sounds like either the switch is buggered. Or more than likely. Theyre wired up so as they provide daylight running lights. Some bikes are like that. Most people always ride with them on anyways Quote
Guest Posted June 16, 2009 Posted June 16, 2009 Sounds like either the switch is buggered. Or more than likely. Theyre wired up so as they provide daylight running lights. Some bikes are like that. Most people always ride with them on anywayshave a look on google it could be that the SE was set up like this.. also is it an import? i know (on my 82 katana, the switch was set to on as they had as an issue of eating regulators/rectifiers, and this kept the voltage down..)also check your air filter it might be the source of your hot starting (not) issue... Quote
Bill_on_a_bike Posted June 16, 2009 Posted June 16, 2009 Lol where did you get this poor bike from!? Quote
Guest Posted June 16, 2009 Posted June 16, 2009 XV750, check out the Virago site, covers the XV750, (i know yours is pre-virago, but you've gotta have a name for a site...)the boys and girls on there will have a better knowledge of all things XV.. including your lighting issue, whether its standard or not..http://www.thevirago.co.uk/also has links to manuals etc.. Bill, Helpful as ever i see................... Quote
Bill_on_a_bike Posted June 16, 2009 Posted June 16, 2009 I try my best frankie.And in the end he did let the oil out! Quote
Stephen Posted June 16, 2009 Posted June 16, 2009 i thought most bikes had dipped beam on at all times, to help you be seen. All bikes i've seen recently are like this. The switch is just to change to full beam when it's needed Quote
Guest Posted June 16, 2009 Posted June 16, 2009 i thought most bikes had dipped beam on at all times, to help you be seen. All bikes i've seen recently are like this. The switch is just to change to full beam when it's needednot in 82 they didn't, we didn't have front brake lights either.. its called progress. like seatbelts and airbags,, the H&S will get you in the end... Quote
Guest Posted June 17, 2009 Posted June 17, 2009 been offered £800 for it, some one came round as he saw it in the garage last night, im not going to sell it yet, if i sell it for £800 ill be geting over double for what i paid for it, hahahaahha. Quote
