Guest Posted June 17, 2009 Posted June 17, 2009 Hi all.I'm wanting to clean the oil filter screen on my CB125 twin (87') but the Haynes says i need to replace the case gaskets and some seal but i dont seem to be able to find them anywhere. I tried CMS but they seem to want like £10 for delivery?I need a sealing O ring for the case wall recess and a right hand c case cover gasket. ebay only has engine gaskets sets that i'm sure dont inc the gaskets i need.Any suggestions?Cheers Quote
Guest Posted June 17, 2009 Posted June 17, 2009 Hi all.I'm wanting to clean the oil filter screen on my CB125 twin (87') but the Haynes says i need to replace the case gaskets and some seal but i dont seem to be able to find them anywhere. I tried CMS but they seem to want like £10 for delivery?I need a sealing O ring for the case wall recess and a right hand c case cover gasket. ebay only has engine gaskets sets that i'm sure dont inc the gaskets i need.Any suggestions?CheersGet the part no's of CMS and cost them up with your local dealer, no P&P.. Quote
Guest Posted June 17, 2009 Posted June 17, 2009 Can i get away with reusing the old gaskets or am i just asking for trouble?! Quote
Guest Posted June 17, 2009 Posted June 17, 2009 Can i get away with reusing the old gaskets or am i just asking for trouble?!i haven't worked on many hondas, but if you are taking engine covers off then i would replace the gaskets.. otherwise money saved now may need to be spent later.. along with additional time etc,.. is this the page.. the gasket and o-rings will be about £15 plus fresh oil.. still a cheap job....http://images.cmsnl.com/img/partslists/ ... 8_bfcf.gif Quote
Guest Posted June 18, 2009 Posted June 18, 2009 Found a UK suppler so i'll do a proper now! http://shop.wemoto.com/index.dyn Quote
Guest Posted June 18, 2009 Posted June 18, 2009 Found a UK suppler so i'll do a proper now! http://shop.wemoto.com/index.dyni've used wemoto many times, good operators, .. Quote
