Guest Posted June 17, 2009 Posted June 17, 2009 (edited) im going to be tidying the bike up, so ill start a new topic, on everything i do with it, going to be buying a speedo cable, throttle cable, new air filter and oil change and filter, and than run it for a month, Edited June 22, 2009 by Anonymous Quote
Guest Posted June 17, 2009 Posted June 17, 2009 if you cant get a panel, how about making two up in alloy, one for each side.. been done loads before on cruisers, so would suit your bike.. just need to make a template and get some sheet alloy.. and then bolt them in position.. just an idea.... Quote
Guest Posted June 19, 2009 Posted June 19, 2009 hi,just done oil change oil filter air filter and speedo, Quote
