I've just put led indicators on my bike, and the flashing rate wont slow down to a normal rate even with the motrax flash it relay. Its a honda specific relay so should definatly work with my bike
The bikes original relay is a 3 pin, but the motrax relay seems to only have 2 pins?? :?
Guest philgale
when i fitted LEDs i had to get a separate resistor to slow the rate down
Crisis over! I was mistaking the headlight relay for the flasher relay :D
got it going now
