slipping throttle
my throttle grip is slipping, the throttle inside is going back fine but the grip is actually kinda useless. say i have it on full throttle on the inside the throttle will slip back while im still holding it making it slow down. its a pain in the ass, iv tried tape and glue and they havnt worked. the lads from maintenence say that silicoln might work, will it help?
thx
thx
take the grip off and give it a good clean with white spirit to get all the grease off (inside the grip and the handle bar). let it dry for 1/2hr then try glueing again. silicon sealant will work too but only if you get all the grease off first.
go to shop buy new grips pull old ones off and replace with new :wink:
cost about £10
oh and give the throttle tube a good clean to remove any grease before fitting new grip
:stupid: That's what I did before fitting my heated grips. White spirit is the way forward! I've heard a few things work well, super glue and photo spray adhesive are the best ones. The thing is, if you take the grip off then it'll've stretched somewhat and there's no way back. So I'd have to go with what Stu said and just get some cheap ones (or get heated grips), then clean everything with white spirit and get it sorted.
I spose it's something you want to get sorted sharpish. Annoying but also dangerous if you're pootling along at high speed and the throttle shuts off with traffic behind :shock:
i found a throttle sleeve and some grips (just to be sure) it a honda throttle sleeve tho. single cable should that be ok?
Depends what bike you ride... :roll: ! If it's a Honda that takes that throttle sleeve then you'll be fine. I wouldn't have thought you'd need a new sleeve thought to be honest, aren't they all made of plastic so can't shrink anyway?
the plastic sleeve sould be fine, give a clean and get new rubber grips.. if fitting heated wire them up prior to fitting and let them get warm, makes it easier to slide them on.. (pinched from someones post)
