Just discovered when I turned my trousers inside out to let them air a bit that there are pockets to insert hip armour but none in there. Where's the best place to buy additional armour inserts from these days? It's for a pair of Frank Thomas Aquaforce trousers. There's space for the armour so it may as well be used!
Look at which ones they are designed for then get on the web... More than likely they will be Knox inserts...
Doesn't seem to say anywhere on the trousers or the knee armour what make it is. I'll look at knox and see if they look similar.
Have a look at the Frank Thomas web site. They will probably be able to tell you mate... :D
Tried that didn't find any info. Doesn't have to be the same make, I'll check out a couple of shops online, just wondered who has the best deals on them.
Looks like it's Arma-Flex armour.
Have a look round the web and see what's cheapest..
Great , it is Armourflex CE armour :)
Sorted thanks Korben
