Seized clutch adjuster (following on from clutch issue?)
Hi,
I have been intending to adjust the clutch cable on my FZS600 Fazer because the freeplay adjuster at the lever was at its furthest out (minimum freeplay). Anyway, I removed the rubber cover and tried to loosen the nut that allows me to turn the cable adjustment screw but it is totally seized. Looks quite rusty! Any ideas how I can loosen it, so that I can make the necessary adjustments?
Cheers
N
:stupid:
dont rush it, give it some WD40 and take things slowly..
a cup of tea is the best tool....
