Guest Posted July 10, 2009 Posted July 10, 2009 hi new to the site but need some help the gear change on my bandit 600 is very clunkey how do i adjust my clutch at the botom end can any one help cheers Quote
Guest Posted July 10, 2009 Posted July 10, 2009 (edited) look at the sprocket cover down by the gear lever..you'll see the cable going in the top with a rubber boot, lift boot and theres an adjuster there similar to one at lever end. also prise of rubber grommet (black round rubbery thing below cable..)can be adjusted here too.. if you have a look on Guides/manuals, i have posted the GSXF manual, the GSF has the same clutch and adjuster as its the same engine, find the page and print it off..EDIT: http://www.themotorbikeforum.co.uk/view ... 27&t=21817 Edited July 10, 2009 by Anonymous Quote
Guest Posted July 10, 2009 Posted July 10, 2009 say hello in Newbies so we can all see ya, and say Hi.Hi from me anyways, Quote
