wiffers Posted July 17, 2009 Posted July 17, 2009 http://www.shockdoctor.com/product/ejec ... l-kit.aspxAnyone use one? Quote
MtotheJ Posted July 17, 2009 Posted July 17, 2009 But surely if your helmet fits correctly, there shouldnt be any room for the bladder to inflate? Quote
Gem Posted July 17, 2009 Posted July 17, 2009 I want to see a video of how this works because I can't quite imagine it. And ditto what Matt said, if the helmet fit properly then inflating it would squish the riders head further into the helmet's padding at the front, wouldn't that be uncomfortable if the rider actually did have an injury to their neck or spine?? Quote
Colin the Bear Posted July 17, 2009 Posted July 17, 2009 Helmet Removal system.PSSSSSSSST........AAAAAGGGGGHHHH!!!! .........undo the chinstrap........ffffftttt........look at it go Quote
wiffers Posted July 17, 2009 Author Posted July 17, 2009 Stays deflated until paramedics arriveThey can then inflate to push your helmet off ... rather than having to pull it and risk stretching or twisting your spine ...Clever Quote
Guest Posted July 17, 2009 Posted July 17, 2009 Inflating it may cause it you move your head to push it in an undesired way though, not worth the risk surely.. so any decent paramedic would leave it I'd have thought.. Quote
Guest philgale Posted July 17, 2009 Posted July 17, 2009 Stays deflated until paramedics arriveThey can then inflate to push your helmet off ... rather than having to pull it and risk stretching or twisting your spine ...Clever there will still be pressure on your head, either the helmet or the bladder.....i dont see how you could safely remove a lid Quote
Colin the Bear Posted July 17, 2009 Posted July 17, 2009 Yes lets keep the helmet on till you're fully recovered. Quote
Guest Posted July 17, 2009 Posted July 17, 2009 The helmet keeps the brain bits all together.Chicane has one of these fitted and his hat still fits his head. Quote
skatefreak Posted August 13, 2009 Posted August 13, 2009 From what i can deduce it is there so that when it inflates it will push the head down and out of the helmate.This seems like a very good idea because to remove a helmate the emergancy services would have to pull on it therefore exerting force on the neck and spinal area which is not good!Very very good idea and i would go for it in a heart beat IF i ever expected the emergancy services to be trained to use this kind of thing... which i very much doubt in this counrty It would however be a fantastic addition to lip protection and would be fantastic if it became a basic and widly spread feature on all helmates, and as long as the services learnt how to use them -Jvc Quote
jamesw Posted August 13, 2009 Posted August 13, 2009 Every action has an equal and opposite reaction. You will still exert force into the neck and spine, just in the opposite direction so instead of stretching the neck, you compress it. Whether or not that is deemed safer i'm not sure, I guess it depends on the injury (if there is indeed an injury.I suppose it may be possible to support the head under the chin and take some of the force that way. I still remain to be convinced. Quote
