Startor motor on a bike i am goin to look at tomorow is in need of a replace.
The brushes are worn down quite bad... now do you think any brushes(universal) would replace them?
or a whole new startor motor is the way to go?
oh, bike is a cagiva river 600
Josh
x
THANKS
Replacing the brushes is always worth a try. You can make some out of an over sized pair with a Swiss file and a little patience. Clean and polish the commutator too. Check the motor over with a multi meter if anything looks burned. 8-)
