Guest Posted August 5, 2009 Posted August 5, 2009 Recently I have had a problem with my digital speedometer. It will not register the correct speed.For a few weeks now it will not go over 10MPH even though I no that I am traveling at a greater speed.Has anyone had the same problem and if so dose anyone have any ideas on how to rectify it? Quote
Guest Posted August 5, 2009 Posted August 5, 2009 the speedo drive in the front wheel is a known fault, if i remember right its a 60 quid fix, or take the wheel off and have a good clean, it might work Quote
jamesw Posted August 7, 2009 Posted August 7, 2009 I can't help unfortunately, however it may be worth having a look over at triumphrat.net. There's a lot of good info over there. Quote
Guest Posted August 9, 2009 Posted August 9, 2009 the speedo drive in the front wheel is a known fault, if i remember right its a 60 quid fix, or take the wheel off and have a good clean, it might work Thank's. I will give it a go next time i'm off. Will let you know if it worked. Quote
