collier32 Posted August 5, 2009 Posted August 5, 2009 on the way to work this morning got something in my rear tyre so its now got a slow leak some people have said get it plugged but i dont like the sound of that i dont think i would trust the tyre.What are your opinions on plugging punctures Quote
YamahaWolf Posted August 5, 2009 Posted August 5, 2009 I think if you have a puncture get it sorted properly. Quote
Guest Posted August 5, 2009 Posted August 5, 2009 having a plug wouldnt bother me, providing the hole is a hole and not a tear, especially if the tyre has loads of life in it, if the tyre is on its last legs then get a new one Quote
Pete Posted August 5, 2009 Posted August 5, 2009 Take it to get a plug! The garage will look at it and if they think it's unsafe to plug they won't do it.Or you could just leave it in there...though I don't recommend that! I know someone who got a screw in his back tyre a couple of weeks after fitting it, thought balls to getting a new one and rode to the south of France and back on it! Not very responsible IMO, but a plug is fine. Quote
Guest Posted August 5, 2009 Posted August 5, 2009 It depends where the hole is on the tyre, and how much tread u got left in the tyre as to whether it can be/ is worth doing.Take it to the tyre shop and they will advise you Quote
Guest Posted August 5, 2009 Posted August 5, 2009 If the tyre shop think its safe to plug the tyre then it WILL be fine to do it.I had the 'almost new' rear tyre on my 1098 plugged, I wasn't too keen on having it plugged at first but it lasted the life of the tyre and all the abuse I could throw at it! Quote
Voodoo Posted August 5, 2009 Posted August 5, 2009 Had loads of tyres plugged over the years and never had a single problem. On another note, my car had a slow puncture, so I used that slime stuff, and its worked a treat! Quote
truxx Posted August 5, 2009 Posted August 5, 2009 I have also used loads of these types over the years: On both cars and bikes and never had a single problem with it.It cost me about £10 from ebay and does 12 punctures for that. Quote
Alex Gold Posted August 5, 2009 Posted August 5, 2009 However it seems to me to be a massive mystery how you actually use the kit! Quote
Guest Posted August 5, 2009 Posted August 5, 2009 http://www.youtube.com/watch?v=9KCPwlyUUrk&NR=1 Quote
Guest Posted August 5, 2009 Posted August 5, 2009 Speaking as an ex tyrr fitter/ grease monkey person ....Plugging a tyre is perfectly safe. Assumuing of course it is done correctly, bit like everything really. Quote
bex Posted August 6, 2009 Posted August 6, 2009 as people have said, take it to shop n ask the, it depends on where the hole is, have you got slime in your tyres as this stuff (althoguh tyre shops hate us using it) is good for times like you have, Quote
collier32 Posted August 6, 2009 Author Posted August 6, 2009 thanks for the replies but i had a new tyre fitted just so my mind was at rest Quote
