Guest Posted August 8, 2009 Posted August 8, 2009 To improve motorcycle safety many countries order the wearing of protective clothing by motorcyclists, especially a helmet. Other protective equipment may include certain types of jackets, gloves, boots, and pants. Jackets meant for motorcyclists are typically made of nylon, leather, or Kevlar. These jackets usually include heavy padding on the elbow, spine, and shoulder regions. Gloves are generally made of leather or Kevlar and some include carbon fiber knuckle protection. Boots, especially those for sport riding, include reinforcement and plastic caps on the ankle and toe areas. A well-protected motorcyclist will wear boots with heels that fit on motorcycle foot rests (pegs) and provide good ankle support. Pants are usually leather, nylon, or Kevlar. Except for helmets, none of these items are required by law in any state in the U.S. but are recommended by many of those who ride.Types of clothingLeather Clothing: Leathers are 1-piece suits, or 2-piece jackets and trousers worn by motorcyclists mainly for protection in a crash. The leather used is not fashion leather but protective leather which is stronger, rather flexible and much tougher. Both leathers and joins (seams and zips) should be officially tested for ergonomics and impact scrape, cut, tear and burst resistance. They do not have to be too heavy and there is no such thing as rivalry leather - just safe and unsafe leather and joins. Typically, an accident at a race track will result in the racers sliding, rolling and tumbling for reasonably long distances and long times compared to an accident on the public road. This is because of the large safety run-off areas found on most race tracks; hence racers have a much lower probability of hitting hard vertical solid objects during a crash. Some racing leathers have additional protection properties to increase sliding and decrease bouncing and rotation. To decrease or prevent such injuries, most modern racing suits have an area that helps sliding at the knees, shoulders and elbows – often made of titanium or high-density plastic, so the rider slides more along the track environment and so decreases the bouncing and rotation through the air, which may cause inferior injuries from angular accelerations and rotational forces
Guest philgale Posted August 8, 2009 Posted August 8, 2009 please if you post something put the source from where you got it from sourced from wiki
Guest Posted August 8, 2009 Posted August 8, 2009 http://www.themotorbikeforum.co.uk/view ... 46&start=0
