Guest Posted August 15, 2009 Posted August 15, 2009 hi all ,got a honda dylan 125 (04plate), when driving for about 20 mins i get water coming out from the front area of the bike.took the bike to the garage the guy looked at the bike and put a new fan switch on , but still did not cure the problem ,the guy checked all the hoses and left it runing for a while to see if there are any air locks, also he removed a small panel underneath the bike so it had a better air flow to the radiator ,this still did not work ,i got no warning lights coming up either .any help would be most appricated thanb you Quote
Colin the Bear Posted August 16, 2009 Posted August 16, 2009 Could be a blocked matrix. Is it filled with the recommended coolant. Just water can cause overheating. Drain , flush and refill. Quote
