Hello,
Normally when I start my bike up I can see the oil drain away into the engine via the viewing window. usually the window is full and it is empty a few minutes after the engines running.
In the last couple of days I have noticed that only about half the oil is draining away, and wonder if this is an indication that there is a problem - obviously worried that not all the oil is going where it should.
If anyone could shed light on whether this is indeed a problem or is it is normal that would be appreciated.
Cheers
with the bike on a centre stand and on level ground, the oil indicator window should only be half full with the engine 'off' any more than this and it is over filled.
