jimsoon Posted August 20, 2009 Posted August 20, 2009 got a rear paddock stand, but i need a front one to remove the front wheel, just wondering whats the better option, 1. front paddock stand2. yoke/headstock standI assume that with both you can remove the front wheel, as the paddock stand 'cups' the bottom of the forks?? dont really want to spent £100 on an abba stand. Quote
Stu Posted August 20, 2009 Posted August 20, 2009 either are as good as each other just remember to use the rear one at the same time otherwise the bike can go over Quote
Guest Posted August 20, 2009 Posted August 20, 2009 personal preference for a yoke stand, as it has more uses, can drop the forks as well. where as a front paddock only allows removal of the front wheel.. again, always use with a rear paddock stand.. Quote
Guest philgale Posted August 20, 2009 Posted August 20, 2009 headstock stand any day of the week, used paddock stands and to be honest my bike kept falling off it as i tried to put it on, headstock stand is much safer and you can remove the forks if need begot one from ebay for 55 i think Quote
Stu Posted August 20, 2009 Posted August 20, 2009 headstock stand any day of the week, used paddock stands and to be honest my bike kept falling off it as i tried to put it on, headstock stand is much safer and you can remove the forks if need be user error Quote
Guest philgale Posted August 20, 2009 Posted August 20, 2009 headstock stand any day of the week, used paddock stands and to be honest my bike kept falling off it as i tried to put it on, headstock stand is much safer and you can remove the forks if need be user error many people tried and could do it, it was as if my forks are different lengths Quote
Stu Posted August 20, 2009 Posted August 20, 2009 im guessing this is on the sv ? and you was using a stand that has cups that sits under the forks?if you look at the forks on the sv they taper off on both sides so when you try to lift it the stand just slides off you have to get someone to lift the front up as you put the stand under thats what i had to do with our kids sv but it went on and stayed on Quote
Guest Mr Miller Posted August 20, 2009 Posted August 20, 2009 So you're saying he's a sausage-fingered, cack-handed numpty then, Stu? Quote
jimsoon Posted August 20, 2009 Author Posted August 20, 2009 Good stuff, think I'll go with the yoke stand then, there's one in town for just under £50.Cheers Quote
Guest Posted August 20, 2009 Posted August 20, 2009 im guessing this is on the sv ? and you was using a stand that has cups that sits under the forks?if you look at the forks on the sv they taper off on both sides so when you try to lift it the stand just slides off you have to get someone to lift the front up as you put the stand under thats what i had to do with our kids sv but it went on and stayed on had a similar problem with an prillia rs, the forks were compressing when on the stands at different rates, probably badly filled, but i was changing a speedo drive, my mate (his bike.,.) ended up trying to hold whilst i got the drive and wheel on.. on my bandit/katana/gsx, i am able to jack up the front of the bike and support on wooden blocks, off the crash posts/engine bars... but with an R6 you have the fairing.. Quote
Guest philgale Posted August 21, 2009 Posted August 21, 2009 im guessing this is on the sv ? and you was using a stand that has cups that sits under the forks?if you look at the forks on the sv they taper off on both sides so when you try to lift it the stand just slides off you have to get someone to lift the front up as you put the stand under thats what i had to do with our kids sv but it went on and stayed on exactly, and what a ball ache it is trying to put it on when nobody else around....so its going and my bike is currently on a headstock stand Quote
