while at low speed the temp gauge can sit just below red, is this norm? (high speed = more air gettin to the engine coolin it down?)
coolant has been topped up this morning(as i noticed was doin this last night and it was low) but will check before i set off home whether it has gone down, with a possible leak?
Anybody ave any ideas ?
Sorry info is vague, at the GFs :)
bike is a gpz500s '95 (restricted)
Thanks
Josh
x
My CBR sits at over 100 degrees in traffic then cools down was soon as i strat moving
Yeah mine gets hot in traffic too - more reason to filter! I first noticed last summer when it started over revving when at a stand still :? !! I tend to filter now or flick the kill switch if I'll be still for ever such a long time.
doesnt ever seem to go to red.. although ive noticed the heat is from the radiator and not the engine itself?
water pump?
Fan, if its fitted?(wtill tryin to find online manual)
head gasket? im just throwing ideas out there..
air lock somewhere?
collant level is still tehe same :)
Josh
x
Well, its the radiator that disperses the heat innit ? So most of the head should be in that.. no ?
is it actually going in to the red ?
not yet but its noticably changed (im pretty sure) over the last few days...
either that or the heatwave has made it hotteR?
you can smell the heat if that maeks sense lol
Josh
x
keep an eye on it if it goes in to the red then stop
does the fan cut in ?
if it has been warmer when you noticed it then thats probably why
mine can get up to 111°c before the fan comes on
how would i notice the fan comes on? if itsgot one fitted :)
safe to ride still ?(well ive been riding it since just keepin a eye )
Josh
x
look at the back of the radiator for a fan look at this one on ebay :wink:
http://cgi.ebay.co.uk/Kawasaki-GPZ500S- ... 286.c0.m14
you will hear the fan come on
you could always start it and let it run till it comes on to make sure it works :wink:
chances are its ok and you havent noticed it before
THANKS Stu!! :)
much appreciated matey :)
will look tomorow before me ride :)
Josh
x
thanks guys just one quick thing,
fan does work :)
But after turnin off when the bike is hot, there are bubbles comin up through the coolant (where you pour it in) Anything to worry about?
Ta
Josh
x
if there's bubbles its probably not be bled properly.. check out coolant bleeding in a manual..
:stupid:
or the coolant is boiling
you are putting a coolant mix in arent you and not just water ?
water will boil where as coolant raises the boiling point and aids cooling too :wink:
:stupid:
yup bought a new bottle from local bike shop :)
tryin to find this bleed screw tho..... hmmmm
Josh
x
:stupid:
Josh
x
have a look at the manual, generally it is at a high point in the coolant piping.. on my ER-5 (same engine) it was under the tank, as you needed the tank off to fill the coolant...
checeked the manual, im either blind or stupid i cant see it! lol
Will go look at tank in a mo tho :) thanks
Josh
x
see page 48/49..
the GPZ has a header tank (ER-5 Doesn't) you need to take the lid off the header tank and off the radiator. shown on pages above, the air will the escape and the collant will level off, top up as required, re-fit both lids and test.. sounds like you have topped up the bottle but have an airlock on the other side..
http://www.scribd.com/doc/4632187/Kawas ... nce-Manual
just a update: kept a eye while on it commuting today, didnt seem to get as hot as before which is a good sign :)
Still boiling bubbles after a ride, can here them lol.
Maybe was just teh weather.. i think ill give it a good flush out when i get a chance :)
Thanks gfor your helps,
gets any worse will post here again lol
Josh
x
