Mk5Centurion Posted August 24, 2009 Posted August 24, 2009 Project ZZR part 56; plugs - check, air filter - check, new battery - check, fresh petrol - check, leak in petrol tank - bu**er.Tis a small leak - what can i seal it with?Ta Quote
Guest Posted August 24, 2009 Posted August 24, 2009 petseal... theres a thread on here, from DJRose, he was looking at similar, but got a replacement tank instead..http://www.bikersguidesw.co.uk/petrol_tank_sealing.htmhttp://www.themotorbikeforum.co.uk/view ... +tank+seal Quote
Pete Posted August 24, 2009 Posted August 24, 2009 I remember a friend of mine having a split in their tank and they got it welded up. You'd probably need to paint over it to protect it after. Quote
Guest Posted August 25, 2009 Posted August 25, 2009 to weld it, you will need it empty AND vented to remove any petrol vapour.... exercise extreme caution... Quote
