Plastic repair Honda xr 125
Hey Guys, First time on the forum so was wondering if anyone could help.
Ive got a Honda XR125 thats had a few scrapes in its time and i was wondering if anybody had any advice on how to repair the plastics. The problem is its not the heavy plastics you get on big bikes which is easyly sanded, filled and sprayed. its a lightweight acrilic style plastic.
And failing any advice on repair, does anyone have any advice on were i can get replacements. keeping in mind there not broken just scrached.
And advise is much apreciated
Thanks
Dan
I would imagine that acerbis or someone else would do the plastics for a common model like that; WalneyFrankie will be along soon - he is a fountain of much knowledge.
Pop into newbies and say hello if your staying! :mrgreen:
the plastics quite soft, but you can polish some out with plastic scratch polish.. used for caravan windows so doesn't scratch/swirl..
if they're cracked a plastic weld, could help, (basically you melt the back of the crack and fill with the plastic that comes with model aircraft (the spare stuff from the frame..) all you need is a soldering iron..
otherwise go for replacements, as mentioned before Acerbis do stuff, used a lot for Paris-Dakar and racing as its easily replaced..
http://www.mandp.co.uk/products/list/Of ... X-plastics
cheers, good advice,
I think il give it a go befor the end of the month.
second question, does anyone have any idea about replacement stickers?
thanks
