Does anyone know what the torque wrench setting is for the marauder? My mate has one but the service manual that came with it (second hand) is in German!
**Edit - even better would be if anyone knows the size of the socket needed for the bolt on the rear wheel too!
Torque - 47ft/lbs
Size - 17mm
The RH nut is 22mm and the LH end of the axle is 17mm. The hand-wrench supplied in the owner's
tool kit is not robust enough for this application, so most users loosen and tighten with a 17mm wrench on the LH side of the
axle. You can use the tool kit wrench to secure the RH nut while tightening or loosening, however...You just won't be able to
loosen the axle nut with it. Use a pull-bar with the 17mm socket, if possible. Also, a large adjustable wrench on the 22mm nut
works nicely.
