Guest Posted August 30, 2009 Posted August 30, 2009 BMW R45 - 1979 HiBeen working on an old 'airhead' - new battery - all back together - turn on ignition - all warning lights correct - BUTpress ignition start button - nothing dead but brake light comes on - not even click at relay - any ideasto turn brake light off i have to detach front brake handlebar lever switch connectionplease adviseregards Quote
Colin the Bear Posted August 31, 2009 Posted August 31, 2009 Sounds like incorrect wiring or a short. Check what you've been working on to see if you've nipped anything. Otherwise it's circuit diagram and multimeter time. Quote
Guest Posted September 1, 2009 Posted September 1, 2009 hithanx for responsetook off and cleaned handlebar ignition starter - no differenceTHEN JUST A HUNCH - i pulled in the clutch lever and the ignition worked any ideas wots wrongregards Quote
Guest Posted September 1, 2009 Posted September 1, 2009 clutch safety switch, have you got wires under the lever,? fitted to Suzuki's I have had... Quote
Colin the Bear Posted September 2, 2009 Posted September 2, 2009 Some bikes have a clutch sensor so you can start the bike in gear. Might be worth checking it's wired the right way round. Apart from the clutch switch it may be the neutral switch.(Bike thinks it's in gear so won't let you start it till you pull the clutch) Usual thing to check when the starter doesn't work is , kill switch , side stand and in neutral. Some need the clutch lever in as well. After reading again, the brake light is probably the lever switch or the pedal switch Quote
