Guest Posted September 8, 2009 Posted September 8, 2009 Im new to this forum, so im not sure this is the correct place to post etc. Im a bit more used to old cars so bear with me.Ive acquired an old '83 yamaha yz100. Ive stripped the carb (Mikuni) and was trying to set the float height. Ive read that it is supposed to be 16.4mm but I cant work out where to measure it from and to, as the floats are on vertical spindles, unlike previous carbs Ive used.Also does anyone know the adjustments that can be made on the carb?Thanks in advance... Quote
Colin the Bear Posted September 8, 2009 Posted September 8, 2009 Bear with youhttp://i195.photobucket.com/albums/z28/Colin_the_bear/bear_ermm.gifTry here. Your bike may be listed http://www.carlsalter.com/motorcycle-manuals.asp Quote
