Mk5Centurion Posted January 25, 2010 Posted January 25, 2010 Whilst rebuilding the new calipers i've managed to shove a couple of the pistons right flush into the caliper body.I take it if i put them together minus pads and connect up to the lines and m/c i can just pump them back out? Quote
Guest Posted January 25, 2010 Posted January 25, 2010 You would be correct Gently does it though ... Quote
Guest Posted January 25, 2010 Posted January 25, 2010 put the pads in and pump them out, stops them coming to far out.. even better if you slot them over the disc as well. Quote
