honda cr 80 multiple problems
Hi all!!!
Im new to the forums and need a bit of advice about my bike ... here are my problems...
its leaking water through the over flow pipe constantly,
theres a little hole at the bottom of the water pump and theres water leaking from there too, can i do anything about this without changing the pump??
Because of the loss of water will this affect the way that the headgasket works causing overheating??? As ive gone through 3 top end headgaskets??
Hope one of you kind people can help!!
Ta! Jamie :D
SOunds like the bike needs a good service,
The leaky water pump will cause over heating blowing the gaskets and if your not carefull will cause more serious problems if not put right. The only way to put this right and cheapest way in the long run is to replace the water pump. (should be easy enough to get a second hand one)
  • 1 month later...
its leaking water through the over flow pipe constantly,sounds like the spring in the cap is buggered not kkeping the system under pressure
theres a little hole at the bottom of the water pump and theres water leaking from there too, can i do anything about this without changing the pump??yep fraid the seal has gone so it will have to be changed should be able to do this with out renewing the pump just a seal kit
Because of the loss of water will this affect the way that the headgasket works causing overheating?? As ive gone through 3 topendheadgaskets??
yes you will end up cooking and seizing the motor i would advise you have the head skimmed as i think you'll find its warped from over heating thus changing the gasket wont help
Ta! Jamie :D
