Guest Posted March 10, 2010 Posted March 10, 2010 I need to top up the clutch fluid on the Pan - how does one go about it and what does one use to top up with? Quote
Guest Posted March 10, 2010 Posted March 10, 2010 a hydraulic clutch is much the same as a hydraulic brake, so you can bleed, as you would your brakes, to top up remove the lid/cap, and top up with hydraulic fluid, same goes for brake fluid though, if its over 2 years old, you'd be better off replacing it..oh and its the same fluid, theres no such thing as clutch fluid, it is just hydraulic fluid. Quote
Guest Posted March 10, 2010 Posted March 10, 2010 That seemed the most logical way of doing it, but I was worried about damaging the sealing gasket on the reservoir.Ta very muchly. Quote
Guest Posted March 10, 2010 Posted March 10, 2010 take off the gasket when filling and replace prior to refitting the lid..no worries, para, hope your sorted soon. and remember, don't spill any, or if you do rinse away immediately, it eats paint, tyres, and prob fairings..... Quote
