hYpYz Posted March 18, 2010 Posted March 18, 2010 Hiive bought my first big bike this year. Im going for rideouts quite often and im planning to go for track days. I have textile jacket for commuting and im just using jeansI have 500-650£ budget which ill probably be able to bend IF NECESSARYi was looking at some alpinestars leather suits in J&S in Leeds for 400£ i need new boots - 90-150£ and gloves - 20-50£ (boots and gloves alpinestars)guy in the shop recommended berik gear (suit particulary). He said that the leather in those suits is stronger..I was wondering if there is any difference and if it is, is it worth 100£ waiting for your opinions... Quote
Guest akey Posted March 18, 2010 Posted March 18, 2010 For road use, any of the decent brands available will be fine. As long as they fit properly and you look after them.I would say you should be able to get good gear well under your price range, depends if you want to stick with expensive brands like AStars or dont mind looking at some of the cheaper kit, and if you want a suit or a 2 piece or even jacket and trousers that zip together just at the back.Both AStars and Berick kit is pretty good so you wont go wrong with either. Quote
fazerboy Posted March 18, 2010 Posted March 18, 2010 look at the thickness of the hide,a minimum you should get is 1.1 mil thick,but buy the thickest you can afford.but there is also kangaroo skin to consider too,this is lighter and just as strong,but is more expensive too.Get a 2 piece with a full wrap round zip,any less you wont be allowed on a track,but this is better than a 1 piece while riding the roads,as you can take the jacket off Quote
Guest Posted March 18, 2010 Posted March 18, 2010 Kangaroo hide is thinner but offers the same abrasion resistance as cowhide.A good quality set of leathers should be double or triple stitched on all seams.I believe some tracks insist on a one-piece to prevent the tops separating from the pants if/when you slide down the track. Quote
hYpYz Posted March 18, 2010 Author Posted March 18, 2010 if it offers the same protection but its thinner im not going for it definetely not worth extra money.ive seen a nice suit for 400 from alpine stars ill check the stitches next time ill visit the shop. Quote
Guest akey Posted March 18, 2010 Posted March 18, 2010 The point with kangaroo skin is its lighter and more supple than cow hide for the same strength and abrasion resistance.Think of it as the carbon fibre of the leather world.If its an AStar suit mate I can its at least double stitched at all the seams, and that any design is single stitched over the top of the suit (which is fine). Quote
TC1474 Posted March 18, 2010 Posted March 18, 2010 Head injuries, although often the most serious, are not the only injuries motorcyclists suffer. Leg and arm injuries are common, and leg injuries in particular can be serious often causing permanent disability.Under the EC personal protective equipment directive, a series of European standards were developed for motorcyclist protective clothing that was designed to.1. Prevent or reduce laceration and abrasion injuries.2. Prevent or reduce impact injuries such as fractures, broken bones and joint damage.These standards marked with a CE mark are essentially to help riders distinguish between clothing that offers a minimal level of protection, and garments that may look similar but offers very little if any protection at all.Unfortunately for many riders, the buying of new leathers is often no more than a fashion statement as opposed to a desire to maximise their protection, but, contrary to popular believe you can be fashionable and protected.As with helmets, there are accidents and injuries from which even the best or most expensive clothing will not protect the rider for various reasons. It is therefore important not only to try and reduce the severity of the injury as best as you can, but also ensure that the garment is comfortable, does not impede the movement of the rider and will reduce the affects of fatigue thereby aiding concentration.Leather is still regarded as the best form of protection against injury when riding a motorcycle. They are made from a natural material, which is breathable, abrasion resistant and supple. Like a crash helmet, they cannot offer total protection from injury, but they can reduce the severity and long term affects if they fit correctly.Leather garments can be made from 4 different animals, Cow, which is the most commonly used, Goatskin, Buffalo or kangaroo skin.Cowhide is the preferred choice of most manufacturers. It is heavy duty (compared with the others). It is hard wearing, and in the main the manufacturers use 1.4mm thick hides, which means that in the summer weather with the thickness and all the padding they can get hot inside.Buffalo hide is often used on cheaper garments and this can be felt in the overall quality when compared to other leather products. Buffalo is tough, will last well but it tends to be a very stiff leather and can take some time to bed in and soften up.Goatskin although worth considering as an alternative for summer use is very difficult to find in the UK. It is considerably lighter and more flexible than Cowhide, and many consider the goatskin to be stronger than cowhide due to the fibres being more closely knit together than cow skin. The downside is that goatskin stretches a lot quicker than cow so it may require specialist tailoring on an annual basis.Kangaroo is probably the least known of the hides used although they are being used more regularly in very hot climates. The hides are supple, light and quite tough, but it has been found that they can react with sweat particularly when worn by riders who perspire freely. If this were the case then you would probably be well advised to look elsewhere as you may find your suit literally coming apart at the seams.For those considering purchasing leathers for the first time, the question often asked is whether to purchase a suit/jacket combination, two piece suit or a 1 piece racing suit. The choice comes down to individual preference, but here are a few points that you may find useful to consider.1. A jacket and trouser combination is probably the most popular choice for the majority of riders, and, they can be worn singularly or in combination. However, many jackets (not all) have a Thinsulate lining for warmth retention together with a quilted lining. Many riders complain that they overheat in warm weather which can ultimately affect concentration. However, this combination is ideal if you are an awkward size or on a limited budget.2. A two piece zip together suit can be a good choice for a number of reasons.They can normally only be worn as a complete garment thereby maintaining your crash protection.They come in a number of colour choices therefore conspicuity can be enhanced.They are normally lighter than jacket/trouser combinations which for some means they will be more comfortable for summer or warm weather use.When stopping for a break, the jacket can be unzipped from the trousers thereby enhancing comfort when away from the bike.They maintain their shape and size better.They often have features such as perforated leather to allow air to pass through in warm weather, stretch fabric panels behind the knees, waist and inner thighs which again can enhance warm weather comfort.On the downside, it is worth bearing in mind that:-They can normally only be worn as a complete suit.They can take a while to break in and mould to your shape.They are not particularly warm in the colder weather.There are not as many pockets as in a jacket/trouser combination, which for some may be a good thing.The colours tend to be more flamboyant than jacket/trouser combinations.1 Piece suits are the other alternative often favoured by those who ride Supersports or participate in track days. Whilst offering a fair degree of protection, for road use they have often been deemed impractical as you cannot separate them when away from the motorcycle, but more importantly in serious accident situations, the emergency services have occasionally experienced difficulty in rendering an effective diagnosis or treatment simply because they cannot cut through the leather to tend to the riders injuries, or they cannot risk removing the garment without fear of causing further injury. This of course comes down to a matter of preference.Leather is abrasion resistant, and its main function is allow you to slide, thereby reducing friction. From new, leathers should fit as tightly as possible to allow for stretching and moulding to the wearer’s shape. If the leather is a poor fit then there is the possibility that as the rider slides down the road, the friction caused by the road surface will cause the leather to snag. This could cause a flailing limb to snag and whilst the torso is still travelling at speed, the flailing limb will slow down too quickly and can result in severe injury. On the plus side, a good fitting leather can slow down any potential blood loss, particularly internal blood loss, or it can at least stem the flow until medical help arrives on the scene.If you are unfortunate enough to be involved in an accident as a result of which you are injured (and we all hope that it doesn’t happen), at least you can be comforted that the severity will be less than if you were wearing non protective clothing, and the sympathy you receive from the emergency services and Hospital will be far more favourable than your compatriot wearing his jeans and trainers. Quote
RiffmasterII Posted March 18, 2010 Posted March 18, 2010 Good sound advice there TC, dont suppose you have anything similar on textiles do you as Im just looking at buying a new suit and still unsure what to go for, id rather go textile so I can use it all year round Quote
hYpYz Posted March 19, 2010 Author Posted March 19, 2010 this is very helpful. get that post seperated from this thread and sticky it somewhere Quote
