Guest Posted April 25, 2010 Posted April 25, 2010 (edited) hi, Any idea's if the rectifier was faulty would this stop the fuel pump or if there is a fuel pump relay on this bike, or anything that may control the pump. Initial problem below, thanks I turn ignition on and engine light comes on, but pump does not prime, engine light still goes out after about 5 seconds.bike wil not start as no fuel getting through. I fitted new pump and worked fine for a very short time then the same symptoms came back, any ideas please, thanks Edited April 25, 2010 by Anonymous Quote
Guest Posted April 25, 2010 Posted April 25, 2010 hi, Any idea's if the rectifier was faulty would this stop the fuel pump or if there is a fuel pump relay on this bike, or anything that may control the pump. Initial problem below, thanks I turn ignition on and engine light comes on, but pump does not prime, engine light still goes out after about 5 seconds.bike wil not start as no fuel getting through. I fitted new pump and worked fine for a very short time then the same symptoms came back, any ideas please, thanksAny idea's if the rectifier was faulty would this stop the fuel pump or if there is a fuel pump relay on this bike, or anything that may control the pump thankswhich bike?if the rectifier was faulty, you could have blown the relay. Quote
