I've just replaced the piston and barrel on my grandsons ped. :shock: It's fairly well run in now but I'm having trouble setting up the idle. It's a slide type that I know well from the old Amal Monobloc :love: but I can't work out if the idle mixture screw is fuel or air bleed. :? It's a right sod to get at without taking off loads of plastic :evil: so it would be handy to know if I'm turning it the right way.
Thanks, the basic setting according to Mr Haynes :wink: is 1 3/4 turns out but it's not happy there and difficult to tell with these little 2 strokes if it's getting richer or leaner as the revs go up whichever way I turn it. It'd probably be easier with the drive belt off as the auto clutch cuts in as soon as the revs rise. 4 strokes and model glow motors are much easier :lol:
Thanks for the info. I now have another rebuild to do as the boy has seized it again after just 150 miles. He says he wasn't ragging it but -------------? This is its final chance, next time it's spares or repair on E-bay. :)
make sure if its 2 stroke that the oil pump is bleed properly and pumping correct amount of oil in if not sure add small amount of 2 stroke oil directly into petrol tank so that will help prevent it cooking might smoke slightly more but if its smoking then its getting oil........lol
