Bike problems (chain spins in gear, bike won't move)
Hello,
I'm not new here, I had an account here but forgot my Username from being inactive for around 6months so had to make a new account >.<
Anyway, basically the problem my bike's encountering is:
It was running fine initially. I drove to the shops close by, approached the carpark in third gear (it's only a 125). I downgeared to first too quick I think and it sounded like something snapped off and came loose or stuck in the engine (basically a rattling noise).
Bike engine stayed on, bike wouldn't move with power from the throttle.
The bike's problems now:
Basically, I start the bike in Neutral. When I hold in the clutch and downgear to first, the chain repetitively spins. I cannot accelerate forward, the chain just keeps turning around and around. I gear back up to Neutral, and down again, and the same happens.
I have no idea what's wrong, but basically my Bike won't move at all. The chain just spins over and over.
More Info:
- I can push the bike around WHILE in gear.
- The back tyre does not lock up if I push it in gear
- After leaving the bike overnight (12-48hours), the bike starts fine and I am able to accelerate in gear (works as normal). After about --30seconds-- of riding it, the same scenario persists. Bike won't move, chain is spinning.
Also, the chain seems 'loose'. I don't know how to explain it, but it doesn't look as tight as it should be.
Any suggestions on the problem? Should I take it to a garage?
Check your rear sprocket. Sounds like you either stripped all the teeth off it, or destroyed the cush in some way allowing it to spin freely.
