Guest Posted July 9, 2010 Posted July 9, 2010 hey, i bought a bike 2 days ago and it runs great when started up, but it won't start up using the electric start. I have to bump start it every time. The electrics all work (not great, but work), the place i bought it off said the battery wouldn't take a charge, and the battery could need replacing. Can anyone just confirm this before i spend my pennys on a battery? Also if it's a new battery I need can someone give me a link or advise on to where i can get the right charger from, thanks Quote
Guest Posted July 9, 2010 Posted July 9, 2010 could be , could be.... You need to check to see if it is charging also though ... this thread has some info you may find usefulhttp://www.themotorbikeforum.co.uk/view ... =5&t=30863As for where, once you google your bike + battery, loads will appear Quote
Guest Posted July 9, 2010 Posted July 9, 2010 thinking .. I know you say it runs fine, when its running .. but it could run, if it wasn't charging efficiently. Just best to sure Quote
Guest Posted July 9, 2010 Posted July 9, 2010 so if a battery isn't charging properly is that down to the reg/rec... is that regulator/rectifier? Quote
