guybandit Posted July 27, 2010 Posted July 27, 2010 Just a quick one, got a set of these today and they come in two parts. The thread has a allen socket and the bobbin just has a tiny 1mm hole through the head. Am i right in thinking that you screw the thread in with the allen key and then tighten the bobbin up wi a tiny screwdriver???if im being thick just let me know. And i have googled it and found nothing, maybe WF will do better.Guy Quote
Guest Posted July 27, 2010 Posted July 27, 2010 bobbin? are you on about swing arm boobins, or bar ends. have you a picture?doesn't matter right the little hole is a grub screw, you tighten this onto the threaded bar, this stop it coming off. however, i have fitted bobbins (on a B6) for paddock stands and IMO i dont like this idea. better to use a bolt from the inside of the swing arm, into the bobbin with some locktite. Quote
guybandit Posted July 27, 2010 Author Posted July 27, 2010 Nice one WF a fountain of knowledge as usual.thanks againGuy Quote
