krazy-ken Posted August 8, 2010 Share Posted August 8, 2010 hi guysjust put aftermarket indicators on my yamaha xj,they were working fine,nice and bright but then the fronts kept going off from time to time,traced it to were the 3 black wires connect under the headlamp for the indicators,i connected all three with the aid of a block connector and now they work but are very very dim and you can hardly see them now,any ideas guys and girls???cheers ken Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted August 8, 2010 Share Posted August 8, 2010 hi black wire is normally earth on the bike try using a better earth point somewhere bolt that holds headlight is often good place Quote Link to comment Share on other sites More sharing options...
krazy-ken Posted August 8, 2010 Author Share Posted August 8, 2010 cheers for your replyi've tried that and now both flash at the same time (like hazard lights)still very dim?? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 9, 2010 Share Posted August 9, 2010 cheers for your replyi've tried that and now both flash at the same time (like hazard lights)still very dim??go back to your work, and solve one at a time sounds like you have your wires mixed up.. they should be colour coded so blue to blue etc, is the norm... Quote Link to comment Share on other sites More sharing options...
polecat Posted August 16, 2010 Share Posted August 16, 2010 hi guysjust put aftermarket indicators on my yamaha xj,they were working fine,nice and bright but then the fronts kept going off from time to time,traced it to were the 3 black wires connect under the headlamp for the indicators,i connected all three with the aid of a block connector and now they work but are very very dim and you can hardly see them now,any ideas guys and girls???cheers kenhave you tried scotch bloc connectors they produce a better seal What year is your yammy cos I could scan the wiring Diagram if you Dont have one ? Quote Link to comment Share on other sites More sharing options...
spunky1976 Posted August 16, 2010 Share Posted August 16, 2010 i recently fitted new ndicators to my thundercat and had the same problem individually wired in they were dim wired both up together they flashed like hazards much head banging and trying different solutions i decided to swap the wires over (they were both black) hey presto working normally and brightly no probs since then either Quote Link to comment Share on other sites More sharing options...
