gsx weak spark
hi. My gsx 600 f has been in the garage for carb and valve ajustments and general check over as it was running poorly now she runs ok but is porducing a pretty low spark and at tick over will die. Could this be down to cdi as all 4 plugs give weak spark.
:stupid: changing the plugs would be first option, and part of the service, so not a wasted exercise...
and the plugs are fed by two coils, so would be unlikely for both ...
make sure the plugs and caps are seated securely, to give least resistance.
i have tested it with some other plugs and it is still a weak spark everything seems to be sealed ok, its just at those low revs it wants to cut out,
how old are the other plugs.. ?
you could try another coil... just to rule it out.. or in..
the other plugs were quite decent of another working bike, i will try and test the coils if i can, is it possible its an engine problem or carbs maybe.
  • 2 weeks later...
ok. cheers i have sourced a new cdi unit so hopefully this does it, could it be anything else other than cdi. when i drove it back from the garage it was a little hard to start and under load strugled to drive, it would also only seem to get to a certain speed/revs
