I can't seem to find anywhere what PLUG CAP my 59 yamaha ybr takes. I've looked everywhere and found nothing.
i've taken the old Plug Cap and the only thing it has on it is 4FP
thanks
Try this link, hope it helps...http://www.yamahamotorcyclespares.co.uk ... del=SPARES Have you phoned a dealer, Do you need the exact one?
You mean just the Spark plug cap?
Just look at the end of your spark plug.
It will either have a nipple or screw thread.
Go into your local unipart or whatever, and ask for one. Or even take the old cap in with you.
It should be pretty easy to see what cap it needs. If you don't have the cap and it is a long one, just stick a tape measure down the port, and see how deep it is to the top of the treads then tell them the size and they will be able to give you the correct one.
